QuickOPC-UA on Linux platform
29 Apr 2023 06:20 #11709 by support
OPC UA, as a communication standard, is platform independent.
QuickOPC-UA, for integrating OPC UA client functionality into .NET-based application, is supported on Linux.
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2....html#Operating%20Systems.html
- learn.microsoft.com/en-us/dotnet/core/install/linux?tabs=netcore2x
28 Apr 2023 20:16 #11708 by Pala
Replied by Pala on topic QuickOPC-UA on Linux platform
Yes excuse me
QuickOPC-UA fir Linux server
I want to connect without to have necessary a Windows server
28 Apr 2023 18:07 #11706 by support
I do not understand the question, because "COM" (Microsoft Component Object Model) can be used to
1) Communicate to the OPC server. This is the case of OPC "Classic" specifications. However, you mentioned QuickOPC-UA, and therefore OPC UA. And OPC UA is not based on COM. So in this case the question makes no sense.
2) Communicate between the OPC client toolkit, and the actual application. COM is not available on Linux so in this case the question makes no sense either.
The only theoretical possibility where COM can be used on Linux (but *not* with OPC UA) is to connect to OPC Classic servers on a network from a client on a Linux machine. That is doable because the DCOM wire protocol has been made public, and there are even some non-Microsoft implementations of it. We have no plans to support that.
28 Apr 2023 14:50 #11704 by Pala
Hì
I wanted to ask if it is possible to have QuickOPC-UA in COM for Linux servers, if the answer is no I ask if its development is planned
