port to activate in OPC-UA
22 Mar 2023 18:04 #11620 by Pala
Replied by Pala on topic port to activate in OPC-UA
not in the COm object we always specify port 4840
but we noticed that using the VPN the connection remains on the 4840
while if we go directly to the public ip the port changes to 4843
22 Mar 2023 17:51 #11619 by support
Replied by support on topic port to activate in OPC-UA
I do not understand your post, there is not enough info in it.
You need to explain the parts involved and who connects to whom and how. An equivalent of box diagram, in words - if there is no box diagram.
22 Mar 2023 17:39 #11618 by Pala
Hì
We are tryng two type of connections
1#
by OpenVPN, connection is ok and log say that I'm using port 4840
2#
directly to public ip, in this case log say that I'm using port 4840 but after swtch on 4843, possible?
