QuickOPC on Windows Server by Apache webserver
08 Feb 2023 11:34 #11520 by Pala
File Name: out_2023-02-08.txt
File Size:2 KB
    08 Feb 2023 11:31 #11519 by Pala
    ok done
    file out.txt in attachment
    08 Feb 2023 11:07 #11518 by support
    Can you please do this from the command line:
    c:
    cd "\ProgramData\OPC Foundation"
    dir /s >out.txt
    and post here the directory listing from out.txt?
    08 Feb 2023 10:34 #11517 by Pala
    is possible to use QuickOPC by Apache Webserver?
    I had try but I have this error:
    Fatal error: Uncaught com_exception:
    <b>Source:</b>
    Opc.Ua.Configuration<br/><b>Description:</b> OPC UA service result - {BadConfigurationError}.
    Cannot access certificate private key.
    Subject=CN=CGI / FastCGI. Cannot access certificate private key. Subject=CN=CGI / FastCGI in C:\Apache24\htdocs\test.php:9 Stack trace: #0
    C:\Apache24\htdocs\test.php(9):
    com->ReadValue('opc.tcp://192.1...',
    'nsu=http://www....') #1 {main} thrown in C:\Apache24\htdocs\test.php on line 9
