600+ warnings in OpcLabs_EasyOpcUa_TLB.pas
17 Jan 2023 17:38 #11443 by support
in general, I agree with you. However, we provide the TLB with the product. The PAS file is generated by Delphi from the TLB (and, in fact, can be different with different Delphi versions), and is only included with the product so that the examples can be compiled right "out of the box".
So, you should address your concern to whoever is responsible for the PAS file generation from the TLB.
17 Jan 2023 15:13 #11442 by KennethFerm
When compiling OpcLabs_EasyOpcUa_TLB.pas in Delphi 11.2 I get almost 700 warnings. I know I can turn them off in the file by adding {$WARNINGS OFF} and {$WARNINGS ON) around the file but I don't want to do this inside your file.
Good programming standard means no errors, warnings or hints.
What is your opinion about this?
