OPC UA .NET C# - pass callback when subscribing multiple items
19 Sep 2022 15:05 #11095 by support
The SubscribeMultipleDataChanges method is available since QuickOPC 2021.3: kb.opclabs.com/What%27s_new_in_QuickOPC_2021.3#OPC_UA_Client-Server .
Either upgrade QuickOPC, or use the approach from the code I provided to achieve the same.
The following user(s) said Thank You: amlynar
19 Sep 2022 14:36 #11094 by amlynar
OPC Labs QuickOPC 2020.3
19 Sep 2022 14:28 #11093 by support
Which QuickOPC version are you using?
19 Sep 2022 14:02 #11092 by amlynar
The SubscribeMultipleDataChanges extension method seems to be documented on the link you sent, but it doesn't recognize it in my program. Below is the error I receive with the directives I am using. Can you provide an example for passing a DataChangeCallback in the EasyUAMonitoredArguments.
using OpcLabs.EasyOpc.UA;
"Error CS1061 'EasyUAClient' does not contain a definition for 'SubscribeMultipleDataChanges' and no accessible extension method 'SubscribeMultipleDataChanges' accepting a first argument of type 'EasyUAClient' could be found (are you missing a using directive or an assembly reference?)
17 Sep 2022 12:34 #11091 by support
you are probably looking for the SubscribeMultipleDataChanges extension method: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...scribeMultipleDataChanges.html .
The other way to do this is to use the DataChangeCallback property ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...uments~DataChangeCallback.html ) in each of the the EasyUAMonitoredArguments passed to the SubscribeMultipleMonitoredItems method.
This is what, internally, the SubscribeMultipleDataChanges does anyway. Its implementation (the code is simplified) looks like this:
static public int[] SubscribeMultipleDataChanges(
this IEasyUAClient client,
UAMonitoredItemArguments[] monitoredItemArgumentsArray,
EasyUADataChangeNotificationEventHandler dataChangeCallback)
return client.SubscribeMultipleMonitoredItems(monitoredItemArgumentsArray
.Select(arguments => new EasyUAMonitoredItemArguments(dataChangeCallback, arguments)).ToArray());
Best regards/S pozdravem
16 Sep 2022 18:56 - 17 Sep 2022 11:14 #11089 by amlynar
OPC UA .NET C# was created by amlynar
I am switching from OPC DA to OPC UA. In OPC DA the SubscribeMultipleItems method comes with a callback argument. For OPC UA the SubscribeMultipleMonitoredItems method does not come with a callback argument. How can I implement a callback for SubscribeMultipleMonitoredItems in OPC UA?
OPC DA Example:
easyDAClient1.SubscribeMultipleItems(items.ToArray(), (_, e) => {
if (e.Vtq != null && e.Vtq.HasValue)
String tag = e.Arguments.ItemDescriptor.ItemId.ToString();
object value = e.Vtq.Value;
itemChanged(tag, value);
OPC UA Example:
easyUAClient1.SubscribeMultipleMonitoredItems(items.ToArray());
Last edit: 17 Sep 2022 11:14 by support. Reason: code formatting
Time to create page: 0.156 seconds
