BadCertificateUntrusted
13 Jun 2022 05:29 #10966 by CJiwan
Replied by CJiwan on topic BadCertificateUntrusted
Thanks for your answeer.
After moving the certificat from the rejected directory to "UA Application" that works fin.
I take time later to read the different doc proposed to improve my "process".
Best Regards
08 Jun 2022 08:59 #10946 by support
Replied by support on topic BadCertificateUntrusted
please read:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0Client-Server%20Security.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Instance%20Certificate.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ry%20Certificate%20Stores.html
Most likely what you need to do is find the rejected server certificate in the "RejectedCertificates" directory, verify that it is the one you really want to trust, and move it to ""UA Applications" directory.
The following user(s) said Thank You: CJiwan
08 Jun 2022 07:33 #10945 by CJiwan
With the following code :
<?php $Client = new COM("OpcLabs.EasyOpc.UA.EasyUAClient"); $EndpointDescriptor = new COM("OpcLabs.EasyOpc.UA.UAEndpointDescriptor"); $EndpointDescriptor->UrlString = "opc.tcp://CX-516F94:4840"; $ServerNodeId = new COM("OpcLabs.EasyOpc.UA.AddressSpace.UANodeId"); $ServerNodeId->StandardName = "Server"; try { $NodeElements = $Client->BrowseObjects($EndpointDescriptor, $ServerNodeId->ExpandedText); } catch (com_exception $e) { printf("*** Failure: %s\n", $e->getMessage()); exit(); } // Display results foreach ($NodeElements as $NodeElement) { printf("\n"); printf("nodeElement.NodeId: %s\n", $NodeElement->NodeId); printf("nodeElement.NodeId.ExpandedText: %s\n", $NodeElement->NodeId->ExpandedText); printf("nodeElement.DisplayName: %s\n", $NodeElement->DisplayName); } ?>
I obtaine the folowing error :
Description: OPC UA service result - {BadCertificateUntrusted}. The certificate is not trusted. --> {BadCertificateUntrusted}. Self Signed Certificate is not trusted. IssuerName: CN=TcOpcUaServer@CX-516F94, OU=Unit, O=Organization, L=LocationName, S=" ", C=DE, DC=CX-516F94.
I do not find/understand in the documentation how I have to manage the Certificate.
Thanks in advance for your help
Christian
