Authentication with X509 certificate
28 Feb 2022 17:19 #10666 by support
The following user(s) said Thank You: federica
28 Feb 2022 15:35 - 28 Feb 2022 15:35 #10663 by federica
I'm using QuickOPC COM, developing in C++.
I need to authenticate to an OPC-UA server using certificates.
In UaExpert I need to specify "Certificate" and "Private Key".
How can I specify this parameters using QuickOPC library?
I think I have found how to specify "Certificate" parameter.
_EasyUAAdaptableParametersPtr IsolatedParameters = m_clientUAPtr->GetIsolatedParameters(); _UASmartSessionParametersPtr SessionParms = IsolatedParameters->GetSessionParameters(); SessionParms->UserIdentity->X509CertificateTokenInfo->FileName = certificateParam;
Is it correct?
  • Last edit: 28 Feb 2022 15:35 by federica.
