resources problem
23 Feb 2022 08:25 #10649 by ulix86
Replied by ulix86 on topic resources problem
Sorry, my mistake, while I was creating EasyUAClient object every 15 seconds, the memory was continuing to grow.
Now I solved.
Thank you for the suggestion
22 Feb 2022 09:53 #10646 by support
Replied by support on topic resources problem
I would recommend to create just one EasyUAClient object, and reuse it. It may (or may not) help.
What you described, however, may not be a problem at all. QuickOPC is written in .NET, with automatic memory management and non-deterministic garbage collection. It would be a problem if the memory continues to grow and eventually runs out. Is that the case?
Otherwise, using memory (if there is plenty available) is for free, and programs can take if they need. It's not like taking CPU or disk time.
21 Feb 2022 15:35 #10644 by ulix86
resources problem was created by ulix86
Hi, I have a problem with computer resources when I run my vb6 exe (QuickOpc 2019.2).
My program starts the OpenConnection function every 15 seconds for testing the status of the machine,
but after few hours the process keeps a lot of resources in Windows TaskManager like 1 GB or more.
I already tried to close every connection and set object to "nothing" but the problem remains.
It's like something does not clear the memory or the connection still open.
Could you help me?
Private Function OpenConnection() Dim Client As New EasyUAClient OutputText = "" Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "Server" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "User" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "Password" ReadArguments1.NodeDescriptor.NodeId.expandedText = "ns=2;s=Channel_1-ExecutionState" Dim arguments(0) As Variant Set arguments(0) = ReadArguments1 ' Obtain values. By default, the Value attributes of the nodes will be read. Dim results() As Variant results = Client.ReadMultipleValues(arguments) ' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As ValueResult: Set Result = results(i) If Result.Succeeded Then If Val(Result.Value) = 0 Then Status = "Off" If Val(Result.Value) = 1 Then Status = "On" If Val(Result.Value) = 2 Then Status = "interrupt" If Val(Result.Value) = 3 Then Status = "listen" OutputText = "Status: " & Status Else OutputText = "*** Failure: Err.n." & Result.ErrorCode & " " & Result.ErrorMessageBrief & vbCrLf End If Next Client.UnsubscribeAllMonitoredItems Set Client = Nothing Set ReadArguments1 = Nothing Set Result = Nothing Erase results Erase arguments End Function
