ReadvalueList error
23 Dec 2021 10:55 #10499 by support
Replied by support on topic ReadvalueList error
Which programming language or tool is this in?
Is 'valore' variable declared somewhere, and if so, how?
23 Dec 2021 10:51 #10498 by info@software2000.it
Good morning,
i am trying to read a value via the readvaluelist method
I am attaching the code used, the succeeded property is truer, there are no messages in exception nor in errormessage, but when I try to assign a variable to the .value it gives me an incorrect type error, I tested with vartype but it would seem that the property .Value does not exist on its own, what can I test further to understand?
ReadArgumentCk=CreateObject("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments")
ReadArgumentCK.EndpointDescriptor.UrlString=alltrim(URI)
ReadArgumentCk.NodeDescriptor.NodeId.ExpandedText=alltrim(nodo)+alltrim(memonic)
ReadArgumentsCheck.Add(ReadArgumentCk)
ValueresultCheck=oClient.ReadValueList(ReadArgumentsCheck)
resultCheck=ValueresultCheck.Item[0]
errore=ValueresultCheck.Item[0].Exception
errore1=ValueresultCheck.Item[0].ErrorMessage
if resultCheck.Succeeded
valore=resultCheck.Value ////////error Function argument value , type or count is invalid :-((((((((
endif
Please help me
