Error Writing a string value -> Write failed. Reason: BadWriteNotSupported
08 Dec 2021 08:04 #10437 by support
I do not fully understand your problem report, but it seems to me that the server is likely rejecting the value you are attempting to write. Although the data type of the variable is String, it does not mean that the server has to accept any string you write to it. From the node name, one can guess that is something more like a number. Isn't it simply that the values like "ABC123", which you have shown, is not the right syntax? Would "123" work?
Do I understand it correctly that you get this error not just with the software written with QuickOPC, but also with other clients?
07 Dec 2021 10:39 #10433 by albi.majun.1960@gmail.com
Hello Support,
in the menatime I did a search on documentation finding the following link:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...mps%20and%20status%20code.html
Applied and tested :
Private Sub Command1_Click()
Screen.MousePointer = vbHourglass
Rem This example shows how to write data (a value, timestamps and status code)
Rem into a single attribute of a node.
'Public Sub Write_Main_Command_Click()
OutputText = ""
Const GoodOrSuccess = 0
' Instantiate the client object
Dim Client As New EasyUAClient
' Modify data of a node's attribute
Dim StatusCode As New UAStatusCode
StatusCode.Severity = GoodOrSuccess
Dim AttributeData As New UAAttributeData
AttributeData.SetValue 12345
Set AttributeData.StatusCode = StatusCode
AttributeData.SourceTimestamp = Now()
' Perform the operation
On Error Resume Next
Call Client.Write(txtServer.Text, txtNodeId.Text, AttributeData)
' or "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
If Err.Number <> 0 Then
risp = MsgBox(OutputText & "*** Failure: " & Err.Source & ": " & Err.Description & vbCrLf, vbCritical)
Exit Sub
Else
risp = MsgBox("Scrittura eseguita...", vbInformation)
End If
On Error GoTo 0
'End Sub
Screen.MousePointer = Default
End Sub
but unsuccessfully: see attachment "Error_2021.12.07@11.35.05.jpg"
Where I'm wrong, again ?
Thanks+BR
Alberto
07 Dec 2021 09:54 #10432 by albi.majun.1960@gmail.com
Hello support,
I'm getting this error in subject simpling writing a string in a field (string), see attachment "Write failed. Reason BadWriteNotSupported_2021.12.07@10.12.37.jpg"
Instruction is quite simple:
server$ = Trim(txtServer.Text)
nodo$ = Trim(txtNodeId.Text)
cosa$ = "ABC12345/2021"
Call Client.WriteValue(server$, nodo$, cosa$)
'txtResult.Text = ("WriteResult= ") & Err.Number & " - " & Err.Description
List1.AddItem ("Errore WriteResult ")
List1.AddItem (Err.Number)
List1.AddItem (Err.Description)
List1.AddItem ("
valore = Client.ReadValue(txtServer.Text, "ns=2;s=CurrentJobs.CurrentJob1.Order.OrderDataControl.SAPNumberResponse")
List1.AddItem (" >>> Response ")
List1.AddItem "SapNumberRequest" & valore
Else
valore1 = Client.ReadValue(txtServer.Text, "ns=2;s=CurrentJobs.CurrentJob1.Order.OrderDataControl.SAPNumberRequest")
valore2 = Client.ReadValue(txtServer.Text, "ns=2;s=CurrentJobs.CurrentJob1.Order.OrderDataControl.SAPNumberResponse")
List1.AddItem (" >>> Read response : ")
List1.AddItem (valore1)
List1.AddItem (valore2)
End If
I was able to do the same action in the same field on july 2021, see attachment for positive results:
What I noticed is that
SourceTimeStamp and ServerTimeStamp values are aligned so 17/07/2021 11:53:xx
Instead today, as you can see from attachment "Write failed. Reason BadWriteNotSupported_2021.12.07@10.12.37.jpg"
SourceTimeStamp 18/11/2021 and ServerTimeStamp 07/12/2021 values are NOT aligned.
I did some search before opening this new topic, also in this Forum, and this error seems to be common an honestly I don't know how hot to fix it with
Which sequence of command have I to perform to fix the issue and to be able to write correcly such a SAP field
Any suggestion is welcome, thanks
BR
Alberto
Time to create page: 0.168 seconds
