Application gets stuck on exit
29 Mar 2011 10:04 #334 by support
R.,
This is going to be nearly impossible to resolve without having a “repro” application.
From the “hints” in the text below, it looks like that the customer is using the COM version of the component, from C++. In general, the exit scenarios get very complicated here, especially when the component is run In-process. Can you please ask the customer what have they checked in EasyOPC-DA Options, and if “In-process server” is checked, then uncheck it, and leave only “Local server” checked?
29 Mar 2011 10:03 #333 by support
<span style="font-family: "Tahoma","sans-serif"; font-size: 10pt">From:<span style="font-family: "Tahoma","sans-serif"; font-size: 10pt"> R.
Sent: Monday, March 28, 2011 7:54 PM
Subject: Data.NET Error
..... [a customer] ..... is using Data.NET and [...] says:
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">Occasionally, my application gets stuck on exit. This seems to happen when there is no actual OPC server that client can connect to. Any attempts to communicate with the server return error as they should, but the program hangs inside __crtExitProcess()/ExitProcess()
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">The dump file is attached. Do you know of anything that may cause such behavior?
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">We do use apartment model for COM:
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">we call CoInitializeEx(NULL, COINIT_APARTMENTTHREADED);
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">And have _ATL_APARTMENT_THREADED flag defined.
<span style="font-family: "Microsoft Sans Serif","sans-serif"; color: black; font-size: 8.5pt">Unfortunately I cannot reproduce the problem with the small app.
The dump file had an error message number 0x80000004: A trace trap or other single-instruction mechanism signaled that one instruction has been executed. I haven’t been able to find any helpful information on this error. Is he just missing the CoUnitialize?
Any ideas on this error would be great.
<span style="font-family: "Calibri","sans-serif"; color: black; font-size: 11pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">R.
