Authentication with username and password with Visual FoxPro
07 Dec 2021 20:15 #10435 by support
Thanks for update, I am glad it is resolved.
The code should check the .Exception for nullness anyway, because there are other possible errors that you cannot prevent.
07 Dec 2021 16:48 #10434 by info@software2000.it
thanks a lot
Indeed, the ErrorMessage property made me understand that the NodeId interrogated was incorrect, due to a code problem there was a terminal space.
thank you again
07 Dec 2021 07:31 #10430 by support
You should inspect the whole Valueresult.Item[0] - and specifically, the .Exception and .ErrorMessage properties.
There is no .Value if .Exception is non-null.
06 Dec 2021 14:41 #10429 by info@software2000.it
Thanks for the reply; I tried to insert the code you reported to me, it does not give me any error, but I cannot read the value of the node, I would expect to find a False value, as correctly I receive if I read everything through the "Connectivity Explorer" example application . I don't know what to do / where am I wrong anymore.
Readarguments1 is a OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments type
ReadargumentsList is a OpcLabs.BaseLib.Collections.ElasticVector
I insert with ReadargumentsList.Add(Readarguments1) the value and the property ReadargumentsList.Count is correctly evaluated to 1 because I simulated only one value to read.
If I use Connectivity excplore the value of the node I read is : nsu=urn:Exor:OPCUAServer:JMobile ;ns=2;s=Tags.Carica_OPCUA
weith my program the value is the same
the property displaystring and toString of readarguments1 is :""opc.tcp://192.168.0.37:48008", "NodeId="nsu=urn:Exor:OPCUAServer:JMobile ;ns=2;s=Tags.Carica_OPCUA "", Value"
I store the result in Valueresult=oClient.ReadValueList(ReadArgumentsList) ///oClient is CREATEOBJECT("OpcLabs.EasyOpc.UA.EasyUAClient")
then I check Valueresult.Item[0] in this case because I added only one value to read, but the . Value property is blank and not false as I expected and as connectivity excplore return too.
Please help me
04 Dec 2021 09:20 #10425 by support
Yes.
Or, you can manipulate these properties right where they are. Nothing forces you to create a new endpoint descriptor if you already have one. That was just an example. Using the code snippet you provided earlier, you could have something like
ReadArgument.EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "user" ReadArgument.EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "1234"
04 Dec 2021 09:18 #10424 by support
Sent: Friday, December 3, 2021 4:05 PM
To: Z.
Subject: Re: Authentication with username and password with Visual FoxPro (Reading, Writing, Subscriptions)
Ok, thanks, but Can I pass rhis descrittor to the object I se for reading item (OpcLabs.EasyOpc.UA" .OperationModel.UAReadArguments)?
02 Dec 2021 17:57 - 02 Dec 2021 17:57 #10423 by support
The UserName and Password properties of UAEndpointDescriptor are not used in OPC UA authentication. You need different ones.
Below is an example of VBScript code that does that; converting to VFP should be straightforward.
' Define which GDS we will work with. Dim GdsEndpointDescriptor: Set GdsEndpointDescriptor = CreateObject("OpcLabs.EasyOpc.UA.UAEndpointDescriptor") GdsEndpointDescriptor.UrlString = "opc.tcp://opcua.demo-this.com:58810/GlobalDiscoveryServer" GdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "appadmin" GdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "demo"
Last edit: 02 Dec 2021 17:57 by support.
02 Dec 2021 16:37 - 02 Dec 2021 17:57 #10422 by info@software2000.it
Dear Sirs,
I would need to authenticate with user and password (the OPC-UA server requires it), to read a series of values ​​by inserting them in an object of type "OpcLabs.BaseLib.Collections.ElasticVector" through the object "OpcLabs.EasyOpc.UA" .OperationModel.UAReadArguments "but I can't.
A snippet of what I do that does not return errors but does not read me the value.
This is an example of code I use, which works fine on servers without authentication.
oClient = CREATEOBJECT ("OpcLabs.EasyOpc.UA.EasyUAClient") ReadArgumentsList = CreateObject ("OpcLabs.BaseLib.Collections.ElasticVector") ReadArgument = CreateObject ("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments") ReadArgument.EndpointDescriptor.UrlString = .... ///// String containing URL) ReadArgument..NodeDescriptor.NodeId.ExpandedText = .... ////// string containing the Nodei ID) ReadArgument.EndpointDescriptor.UserName = "user" ReadArgument.EndpointDescriptor.Password = "1234" Valueresult = oClient.ReadValueList (ReadArgumentsList) result = Valueresult.Item [0] ///// assuming that I have only one value to read, obviously I have more for this use elasticvector)
result.Value should contain the read value of the requested NodeId, specifically a Boolean value but in reality it is always blank.
what am I doing wrong??
Help please
