Alarms and Events
20 Feb 2024 17:46 #12574 by support
Replied by support on topic Alarms and Events
21 Nov 2023 13:26 #12388 by support
29 Sep 2021 16:59 #10240 by support
here is an example. I hope it helps.
# This example shows how to obtain current state information for the condition instance corresponding to a Source and # certain ConditionName. import time import win32com.client serverDescriptor = win32com.client.Dispatch('OpcLabs.EasyOpc.ServerDescriptor') serverDescriptor.UrlString = 'opcae://localhost/OPCLabs.KitEventServer.2' sourceDescriptor = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.AENodeDescriptor') sourceDescriptor.QualifiedName = "Simulation.ConditionState1" # Instantiate the client object client = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient') print('Getting condition state...') conditionState = client.GetConditionState(serverDescriptor, sourceDescriptor, 'Simulated', []) print('ConditionState:') print(' .ActiveSubcondition: ', conditionState.ActiveSubcondition) print(' .Enabled: ', conditionState.Enabled) print(' .Active: ', conditionState.Active) print(' .Acknowledged: ', conditionState.Acknowledged) print(' .Quality: ', conditionState.Quality) # Note that IAEConditionState has many more properties print() print('Finished.')
The following user(s) said Thank You: K-R IKE
29 Sep 2021 10:27 #10238 by K-R IKE
Replied by K-R IKE on topic Alarms and Events
I don't know how to use GetConditionState of AEClient in Python.
teach me please.
Kind regards,
07 Sep 2021 10:14 #10188 by support
We could not get COM events work in Python either.
We therefore suggest to use the "event pull" mechanism supported by QuickOPC: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...#Event%20Pull%20Mechanism.html .
And, here is an example (with the event pull) that works:
# This example shows how to subscribe to events and obtain the notification events by pulling them. import time import win32com.client serverDescriptor = win32com.client.Dispatch('OpcLabs.EasyOpc.ServerDescriptor') serverDescriptor.ServerClass = 'OPCLabs.KitEventServer.2' # Instantiate the client object client = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient') # In order to use event pull, you must set a non-zero queue capacity upfront. client.PullNotificationQueueCapacity = 1000 print('Subscribing events...') subscriptionParameters = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.AESubscriptionParameters') subscriptionParameters.NotificationRate = 1000 hanle = client.SubscribeEvents(serverDescriptor, subscriptionParameters, True, None) print('Processing event notifications for 1 minute...') endTime = time.time() + 60 while time.time() < endTime: eventArgs = client.PullNotification(2*1000) if eventArgs is not None: # Handle the notification event print(eventArgs) print('Unsubscribing events...') client.UnsubscribeAllItems() print('Finished.')
I hope this helps
ZZ
07 Sep 2021 07:19 - 07 Sep 2021 08:56 #10187 by K-R IKE
Alarms and Events was created by K-R IKE
We are considering purchasing your product and are using your free trial version at the moment.
We would like to see how OPC Alarms & Events operate, but OnNotification doesn't execute with the following code below.
Is there any point we are missing?
Or is this something to do with OPC Kit Server side which needs us to do some extra work to make it work?
import win32com.client import win32com.client.connect import time # import pythoncom class EventHandler: def OnEventingFailure(self, sender0, eventArgs): print(sender0) print(eventArgs) def OnNotification(self, sender0, eventArgs): print(sender0) if eventArgs.Succeeded is not None: print(eventArgs.Message) daclient = win32com.client.Dispatch('OpcLabs.EasyOpc.DataAccess.EasyDAClient') client = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient') serverDescriptor = win32com.client.Dispatch('OpcLabs.EasyOpc.ServerDescriptor') subscriptionParameters = win32com.client.Dispatch('OpcLabs.EasyOpc.AlarmsAndEvents.AESubscriptionParameters') serverDescriptor.Host = 'localhost' serverDescriptor.ServerClass = 'OPCLabs.KitEventServer.2' subscriptionParameters.notificationRate = 1000 handler = win32com.client.WithEvents(client, EventHandler) print("Subscribing events...") handle = client.SubscribeEvents(serverDescriptor, subscriptionParameters, True, None) time.sleep(10) daclient.WriteItemValue('localhost', 'OPCLabs.KitServer.2', 'SimulateEvents.ConditionState1.Activate', True) time.sleep(10) client.RefreshEventSubscription(handle) print("Processing event notifications for 1 minute...") time.sleep(60) print("Unsubscribing events...") if handle is not None: client.UnsubscribeEvents(handle) print("Finished.")
Environment:
- OPC Server: OPC Kit Server
- QuickOPC: 5.61
- Programming language: Python 3.9.2
- OS: Windows 10 Pro (Ver.2004) 64bit
Please let us know how to make it work.
Kind regards,
Last edit: 07 Sep 2021 08:56 by support.
Time to create page: 0.797 seconds
