Send a command to the OPC-UA machine for creation of a new order/job
12 Dec 2020 10:22 #9266 by support
Your node ID is probably incorrect, because of the space character (blank) at the beginning. You currently have
" ns=2;s=xxxxCoiler.Global_OPCUA.OPC_sRxChat"
This represents a node ID in namespace 0 with string identifier " ns=2;s=xxxxCoiler.Global_OPCUA.OPC_sRxChat".
What you probably wanted to have is
"ns=2;s=xxxxCoiler.Global_OPCUA.OPC_sRxChat"
which represents a node ID in namespace 2 with string identifier "xxxxCoiler.Global_OPCUA.OPC_sRxChat".
11 Dec 2020 17:03 - 12 Dec 2020 10:13 #9260 by albi.majun.1960@gmail.com
Dears,
I got a look at other posts and seems to be that to write "string value" has to be changed the code approach, so I wrote the following alternative code belove.
I cannot test it now because the Coiler Machine is down for the weekend
So I have to wait till next monday
Any feedback will be appreciate anyway, thanks
Alberto
Dim endpointDescriptor As String '********************** ServerOPCUA$ = "opc.tcp://192.168.1.97:4840" endpointDescriptor = ServerOPCUA$ ' Instantiate the client object Dim Client As New EasyUAClient ' Prepare the arguments Dim WriteValueArguments1 As New UAWriteValueArguments WriteValueArguments1.endpointDescriptor.UrlString = endpointDescriptor '********************** txtChat$ = " ns=2;s=xxxxCoiler.Global_OPCUA.OPC_sRxChat" WriteValueArguments1.NodeDescriptor.NodeId.expandedText = txtChat$ '********************** valore$= "<CMD>NEWJOB|E456||||3345|" WriteValueArguments1.Value = valore$ WriteValueArguments1.ValueTypeCode = TypeCode_string Dim arguments(0) As Variant Set arguments(0) = WriteValueArguments1 ' Modify value of node Dim results As Variant results = Client.WriteMultipleValues(arguments) ' Display results Dim Result As UAWriteResult: Set Result = results(0) If Not Result.Succeeded Then cosa$ = "*** Failure #41: " & Result.Exception.GetBaseException().Message risp = MsgBox(cosa$, vbCritical) Call WriteLog(routine$, cosa$) End If
Last edit: 12 Dec 2020 10:13 by support.
11 Dec 2020 15:56 - 12 Dec 2020 10:12 #9256 by albi.majun.1960@gmail.com
Dears
as you suggested I used the following instruction to write
ServerOPCUA$ = "opc.tcp://192.168.1.211:4840" txtChat$ = " ns=2;s=xxxxxCoiler.Global_OPCUA.OPC_sRxChat" valore$ = "<CMD>NEWJOB|ABC123||||100|" Call Client.WriteValue(ServerOPCUA$, txtChat$, valore$)
but raise up the following error message
11/12/2020 15.18.27 - *** Failure: OpcLabs.EasyOpcUA: The status of the OPC-UA attribute data is not Good. The actual status is 'BadNodeIdUnknown'.
+ The client method called was 'WriteMultiple'.
If I write the string "CMD>NEWJOB|ABC123||||100|" using a OPC-UA client in the same "node id", that is a string type, it works fine
see attachment "manual_input.jpg"
Where is the mistake ?
Alberto
  • Last edit: 12 Dec 2020 10:12 by support.
    27 Nov 2020 16:14 #9226 by support
    It is not clear what your question actually is.
    The part that I understand is that the command you want to send to the OPC UA server is a string, and that you have some knowledge about how that string should be formed. That's good.
    The next thing you need to know is what you are supposed to do with that string, in order to send the command to the server. Here I can be only of a little help - somebody who is in charge of the server or its configuration must tell you.
    One possibility is that the command needs to be written as a value into some node in the server. That would be somewhat similar to your code snippet. You will, however, need to know *which* node to write to. Example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...rite%20a%20single%20value.html .
    Second possibility, more "in line" with OPC UA way of doing things, would be that the command is sent by invoking a UA *method*. You will need to know the node to call the method on, and the method node. Example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...all%20a%20single%20method.html .
    27 Nov 2020 13:24 - 27 Nov 2020 15:54 #9225 by albi.majun.1960@gmail.com
    Dears,
    I have already integrated in an application/service (simple MES) developed in VB6 the customer request like getting in realtime what is runninng and pass all the info needed to the CRM
    The new goal is to create a new order/job by sending a command to the OPC-UA machine, just to increase the interaction between CRM and the production
    The syntax of the OPC UA command is as follows:
    <CMD> NEWJOB | job-code-1 | job-code-2 | coil-code-1 | coil-code-2 | preset-quantity to produce | spring-file-name
    On HDMI of machine will appear the new job, the joblist of the jobs ready to be used...etc etc
    So i was thinking to start with following:
    Dim Client As New EasyUAClient WriteCMD = Client.WriteValueList("<CMD>NEWJOB|Code1|Code2|bundle1|bundle2|3553|D:\MCxFiles\program_to_be_sent.spr")
    orI have to use a different "client.properties ?
    Could you please be so kind to suggest me which kind of function I can use available from the object, to fit the goal ?
    Below the detailed explanation ot technicality of the CMD
    Best regards and thanks for any suggestion
    Alberto
    AUTOMATIC RECEIPT OF ORDER DATA
    The wrapping machine is able to receive, through an appropriately coded OPC-UA message, the data relating to a new next order and to propose it, automatically, to the operator.
    The order sending command must respect the following syntactic rules:
    • the parts in italics must be replaced with the appropriate values, the other strings are prefixed and must be respected.
    • The separator character is the vertical bar "|" (ASCII 124).
    • job-order-code-1 and job-order-code-2 are made up of any 0 to 16 characters and at least one of the 2 must be non-null, otherwise the message is discarded.
    • code-hank-1 and code-hank-2 are made up of any 0 to 16 characters and can be empty.
    • preset-quantity to be produced is an integer greater than zero.
    • spring-file-name is the full path of the spring file and can be empty.
    A queue of orders is not currently managed by the machine, in the case of sending several orders in succession, the last one will overwrite the previous ones. The overwritten orders will be visible as messages and only the last one will be proposed and will be loaded automatically.
    Here are some examples of commands for sending order data via OPC UA.
    Command string
    Note <CMD> NEWJOB | Code1 | Code2 | bundle1 | bundle2 | 3553 | D: \ MCxFiles \ program_to_be_sent.spr All fields are specified
    <CMD> NEWJOB | Code1 || bund1 | bund2 | 3553 | D: \ MCxFiles \ program_to_be_sent.spr
    Second job code empty <CMD> NEWJOB || Code2 | bund1 | bund2 | 3553 | D: \ MCxFiles \ program_to_be_sent.spr First job code empty
    <CMD> NEWJOB | Code1 | Code2 || bund2 | 3553 | D: \ MCxFiles \ program_to_be_sent.spr
    First empty skein code <CMD> NEWJOB | Code1 | Code2 ||| 3553 | Hank codes and empty spring files
    Last edit: 27 Nov 2020 15:54 by support.
