Growing in memory with WriteMultipleValues
17 Jun 2023 08:00 #11812 by support
Please send me the project that reproduces the problem.
16 Jun 2023 16:52 #11811 by linkecubeko
Sorry for the late reply.
I am using OpcLabs.EasyOpcUA version 5.63.246.1, I have a reproducible scenario.
I am writing to the PLC about 150 tags every 3 seconds and the system grows in memory usage and when it reaches 1.5GB the system explodes.
Regards.
26 May 2023 03:51 #11769 by support
as you can see from the forum thread below, the customer did not answer our question, and consequently we have not followed up.
Which QuickOPC version are you using? Do you have reproducible scenario?
25 May 2023 21:04 #11768 by linkecubeko
Sorry for reviving such an old topic, but did you find a solution to this problem? The same thing is happening to me recently. Each call to WriteMultipleValues increases the memory and after a while my application throws System.OutOfMemoryException.
My application is in C# .Net Framework.
25 Dec 2019 20:53 #8110 by support
Which programming language are you using?
25 Dec 2019 20:30 - 25 Dec 2019 20:32 #8109 by kristof2015
I get the problem that each execution of WriteMultipleValues, the memory grow about 200kB.
This not happend with single WriteValue.
Is there some freememory function?
Krzysztof
Last edit: 25 Dec 2019 20:32 by kristof2015.
