block in CallMethod
19 May 2019 08:32 #7395 by support
Replied by support on topic block in CallMethod
the fact that you need to use that extra code for making user authentication is weird. I will, however, investigate it later, because you seem to have a found a reliable workaround. I'd like to focus on the CallMethod issue first.
I have some questions.
1. Please send the full precise text of the timeout error.
2. With the code you have now, does it always time out, or only occasionally?
18 May 2019 19:27 #7394 by kristof2015
Replied by kristof2015 on topic block in CallMethod
Hi, thanks for response.
I'm sure there is no prblem on server side. Works correctly on UAExpert and dataFEED OPC UA Client.
At the moment my solution was create separate executable to just launch the methods, and after its launch, kill the stucked exe.
Of course its temporary solution, willl not be delivered in final proyect. I need to find clean solution.
The code which works is:
Function call_method_opc_pallet(tPallet As Integer, tNode As String) Dim gdsEndpointDescriptor As UAEndpointDescriptor Dim Client As EasyUAClient On Error GoTo ErrHandler If tPallet < 1 And tPallet > 14 Then MsgBox ("Error Pallets: 1-14") Return End If Set gdsEndpointDescriptor = New UAEndpointDescriptor gdsEndpointDescriptor.UrlString = "opc.tcp://" + mHost + ":62542/RobotUAServer" gdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "admin" gdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "admin" Dim inputs(1) As Variant inputs(0) = tPallet inputs(1) = 9001 Dim typeCodes(1) As Variant typeCodes(0) = 6 '(Byte) typeCodes(1) = 7 '(Int16) Set Client = New EasyUAClient Set Client.InstanceParameters.gdsEndpointDescriptor = gdsEndpointDescriptor Set Client.IsolatedParameters.SessionParameters.UserIdentity = gdsEndpointDescriptor.UserIdentity Client.Isolated = True Call Client.CallMethod(gdsEndpointDescriptor, "ns=2;s=Motion", tNode, inputs, typeCodes) Return ErrHandler: MsgBox (Err.Description) End Function
Its works because of this three lines added:
After long time came error of timeout. 2min more or less.
With Anonymous authentication (on other server) "CallMethod" work fine.
Kristof
18 May 2019 14:03 #7393 by support
Alright, in order to figure out the issue with UserIdentity, I would have to see all parts of the code involved. But I guess that's not important at the moment, because you *somehow* got it running (although in a weird manner). Let's focus now on the CallMethod block.
Have you tried the same method with some other OPC UA client, and what were the results? The first thing I want to determine is whether the "block" isn't actually on the server. If it were on the server side, the CallMethod will actually return, but after quite long time (I think the default is 10 minutes, for OperationTimeout on the client side).
And that's another test I want you to make please. Please wait for approx. 11 minutes., and check whether the function returns or not. If it then returns with an error, what is the error?
17 May 2019 14:47 #7390 by kristof2015
lClient.Isolated = True
lClient.IsolatedParameters.SessionParameters.UserIdentity = mEndPoint.UserIdentity
This is what changed.
If method is run like this it works, but app stuck and must be killed for continuing. Without came error as mentioned.
17 May 2019 14:18 #7387 by support
I am confused now. Earlier, you have provided an error message that you get from CallMethod. Now you report something different, but you have not stated what has changed - did the original error simply disappear by itself, or have you changed something in between, and if so, what?
17 May 2019 14:14 #7386 by kristof2015
Hi, thanks for your answer.
Its not a case. This code is working and its just set it as seperate.
But stuck completally. Execute method on server side but stuck. I must kill it to continue. So its not user/password and permisions issue.
Dim lClient As new OLEObject("OpcLabs.EasyOpc.UA.EasyUAClient")
mEndPoint = new OleObject("OpcLabs.EasyOpc.UA.UAEndpointDescriptor")
mEndPoint.UrlString = mHostUrl
mEndPoint.UserIdentity.UserNameTokenInfo.UserName = "admin"
mEndPoint.UserIdentity.UserNameTokenInfo.Password = "admin"
Outputs = lClient.CallMethod(mEndPoint, "ns=2;s=Motion", "ns=2;s=UnloadLoadingStation", inputs, typeCodes)
17 May 2019 14:00 #7384 by support
It is possible that different users have different permissions, and some things works for one and do not for other. But, this is not the case here, for two reasons:
First, the error complains about unsupported user identity type, therefore the authentication does not even occur - the username/password is not supported by the specific server endpoint. Second, the cannot be any difference between read/write and method call, because the error comes from the UA session creation, which happens exactly the same way in both cases, *before* any read/write or method call can be performed. That is, at the moment you get the error, the server does not know what is going to follow, whether read/write or a method call - so it cannot "guess" when to work and when not.
I'd rather suspect that you are doing something different when doing read/write as opposed to method call. Can you place both these things (first any read/write, then method call) into the same piece of code and call them in sequence (and post the code here)? This would make sure they are both using the same parameters. Or (but that's not as hood), post here the code for read/write that works, so that it can be compared against the one that does method call.
17 May 2019 13:13 #7383 by kristof2015
I get some more detailed error. Actually user and pass its correct, because I can read and write variables, only method doesnt work.
Exception code 0: OPC-UA service result - Endpoint does not supported the user identity type provided. = BadUserAccessDenied.
---- SERVICE RESULT ----
Status Code: {BadUserAccessDenied} = 0x801F0000 (2149515264)
Description: Endpoint does not supported the user identity type provided.
---- REMARKS ----
This error should mean an authorization (permissions) problem, not an authentication problem, but some servers are using it instead of rejecting the identity token (BadIdentityTokenRejected).
If you are identifying the client user by a user name token, it could be that the user name/password combination is incorrect.
+ The SDK action called was "static Session.Create".
+ This is a client-side error.
+ The client method called was 'CallMultipleMethods'., (failed on "CallMethod")
17 May 2019 11:46 #7381 by kristof2015
Hi, I have this code:
Function opc_call_pallet(Pallet As Integer)
Set GdsEndpointDescriptor = New UAEndpointDescriptor
GdsEndpointDescriptor.UrlString = "opc.tcp://192.168.240.235:62542"
GdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "admin"
GdsEndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "admin"
inputs(0) = Pallet
inputs(1) = 9001
typeCodes(0) = 6'Byte
typeCodes(1) = 7'Int16
'Dim Outputs(-1) As Variant
Call Client.CallMethod(GdsEndpointDescriptor, "ns=2;s=UnloadLoadingStation", "ns=2;s=Motion", inputs, typeCodes)
End Function
On server without user and password its works but when need it than always get this error:
Can somebody help me.
Kristof
