opc ua
27 Feb 2019 16:36 #7144 by admin
Replied by admin on topic opc ua
As far as I can tell, these questions do not concern the QuickOPC product, and are therefore outside the scope of this forum - sorry.
27 Feb 2019 13:00 #7142 by Parsa
Replied by Parsa on topic opc ua
also the performance is very very slow, is there anything that needs to be done with PORT properties and OPC UA Client Properties (device and port properties screenshots are attached).
27 Feb 2019 12:58 #7141 by Parsa
also the performance is very very slow, is there anything that needs to be done with device properties and OPC UA Client Properties (device and port properties screenshots are attached).
27 Feb 2019 12:14 #7140 by Parsa
iam asking because we are having 46000 tags in one OPC UA client device, out of this only around 10000 tags are showing as active tags in kepware... any solution to to have all the tags configured in OPC UA Client are as active tags all the time????
27 Feb 2019 06:33 #7138 by admin
There is no single answer to this question. It depends on many factors, among them:
- capabilities/performance of the server and the target device
- network permormance
- capabilities/performance of the client device,
- required speed of updates.
The following user(s) said Thank You: Parsa
27 Feb 2019 04:56 #7137 by Parsa
opc ua was created by Parsa
How many tags that one OPC UA Client device can be able to communicate OPC UA Server?
