How to use UnsubscribeMultipleMonitoredItems in Delphi?
07 Feb 2019 05:57 #7068 by alr1976
I don t understand how to convert subscriptionid (integer) to handlearray to use It.
Br Alessandro
05 Feb 2019 10:09 #7063 by support
SubscribeMultipleMonitoredItems returns an array of handles (integers), not a TStringList. And, the array of handles returned from SubscribeMultipleMonitoredItems should be directly usable as the input array to UnsubscribeMultipleMonitoredItems, precisely as it is shown in the example referenced before. If that somehow does not work in Delphi, let me know.
If you only want to unsubscribe *some* tags from the whole set made by SubscribeMultipleMonitoredItems: The positions (indexes) of the handles in the returned array are the same as those in the input arguments array. So, the handles for argument 0 is at index 0, handle for argument 1 is at index 1, etc. So, you can pick the ones you want, create a new array of integer handles, and pass that to UnsubscribeMultipleMonitoredItems .
05 Feb 2019 07:09 #7062 by alr1976
Hi
I do subscribemultiplemonitoreditems and out subscribeid in a tlist. Now i Need unsubscribe some tags. I got my subscribeid list in a tstringlist. How Can unsubscribe some tags from tlist to unsubscribemultimonitoritems?
04 Feb 2019 15:09 #7061 by support
What do you mean by subscribeidlist? Where and how do you get it from?
04 Feb 2019 14:07 #7060 by alr1976
How create handlearray if i have only subscribeid list?
04 Feb 2019 12:09 #7059 by support
Can you please be more specific? - I do not quite understand what the issue is. Did you mean this example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...tiple%20monitored%20items.html
- and do you want to do the same in Delphi, or is your problem different?
04 Feb 2019 10:59 #7058 by alr1976
Hi!
I have a Subscriptionid list but i don t understand how to use UnsubscribeMultipleMonitoredItems in delphi. I have seen documentatione example but in that case is simple because you have HandleArray assigned with Subscriptionid.
Br,Alessandro
