Memory leak
19 Mar 2018 16:25 #6163 by support
Replied by support on topic Memory leak
By using QuickOPC from COM code, you are effectively lots of using .NET code as well. Most likely there is no memory leak at all. For an explanation and a test related to this, see www.opclabs.com/forum/ua-general/2278-internal-long-running-test-results .
Basically, in .NET you cannot expect the memory follow your wishes. It is managed by the .NET CLR and is not deterministic. Specifically, two memory consumption numbers taken at different times do not show anything. The memory consumption may easily drop down later. Allocating and deallocating an object does not mean the memory consumption will go down back to the same amount as before the allocation.
If you are still concerned, run PerfMon together with your app, and collect the necessary statistics over the long run (as shown in the link above, it usually has to be many days, over a week is preferred). Unless the graph shows a clean upward trend, there is no memory leak.
(If you do observe a clear upward trend, attach the collected data and we will look at it).
I would not comment to the use of Visual Leak Detector tool at all, because I do not know the tool and have no plans to look at it. I suspect its use is simply not appropriate to the kind of program we are dealing with.
Regarding your code, I have not spotted anything wrong (but a problem can still be there, too). Not that it is incorrect, but I would highly recommend to move the _EasyUAClientPtr outside of the function, and create it only once. It is a somewhat "heavy" object in terms of what it is needed to create it and or/destroy it, so frequent creations/destructions are not ideal.
19 Mar 2018 16:14 #6162 by federica
Replied by federica on topic Memory leak
Additional details:
using Visual Leak Detector with your demo application "EasyOPCDADemo", the tool reports a lot of memory leaks...
WARNING: Visual Leak Detector detected memory leaks! ---------- Block 329 at 0x068BF728: 24 bytes ---------- Leak Hash: 0xFBD82B5C, Count: 1, Total 24 bytes Call Stack (TID 1028): ntdll.dll!RtlReAllocateHeap() Data: 46 00 45 00 44 00 45 00 52 00 49 00 43 00 41 00 F.E.D.E. R.I.C.A. 31 00 36 00 00 00 AD BA 1.6..... ........ [...] ---------- Block 51275 at 0x07A9D9D8: 1588 bytes ---------- Leak Hash: 0x0433ACAC, Count: 1, Total 1588 bytes Call Stack (TID 9808): ntdll.dll!RtlAllocateHeap() Data: 20 B6 F4 06 01 00 00 00 68 00 00 01 E8 D9 A9 07 ........ h....... 5C 00 44 00 65 00 76 00 69 00 63 00 65 00 5C 00 \.D.e.v. i.c.e.\. 48 00 61 00 72 00 64 00 64 00 69 00 73 00 6B 00 H.a.r.d. d.i.s.k. 56 00 6F 00 6C 00 75 00 6D 00 65 00 34 00 5C 00 V.o.l.u. m.e.4.\. 57 00 69 00 6E 00 64 00 6F 00 77 00 73 00 5C 00 W.i.n.d. o.w.s.\. 61 00 73 00 73 00 65 00 6D 00 62 00 6C 00 79 00 a.s.s.e. m.b.l.y. 5C 00 70 00 75 00 62 00 70 00 6F 00 6C 00 38 00 \.p.u.b. p.o.l.8. 2E 00 64 00 61 00 74 00 0D F0 AD BA 0D F0 AD BA ..d.a.t. ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ ---------- Block 51314 at 0x07A9E028: 1588 bytes ---------- Leak Hash: 0x0433ACAC, Count: 1, Total 1588 bytes Call Stack (TID 9808): ntdll.dll!RtlAllocateHeap() Data: 20 B6 F4 06 01 00 00 00 7C 00 00 01 38 E0 A9 07 ........ |...8... 5C 00 44 00 65 00 76 00 69 00 63 00 65 00 5C 00 \.D.e.v. i.c.e.\. 48 00 61 00 72 00 64 00 64 00 69 00 73 00 6B 00 H.a.r.d. d.i.s.k. 56 00 6F 00 6C 00 75 00 6D 00 65 00 34 00 5C 00 V.o.l.u. m.e.4.\. 57 00 69 00 6E 00 64 00 6F 00 77 00 73 00 5C 00 W.i.n.d. o.w.s.\. 52 00 65 00 67 00 69 00 73 00 74 00 72 00 61 00 R.e.g.i. s.t.r.a. 74 00 69 00 6F 00 6E 00 5C 00 52 00 30 00 30 00 t.i.o.n. \.R.0.0. 30 00 30 00 30 00 30 00 30 00 30 00 30 00 30 00 0.0.0.0. 0.0.0.0. 30 00 35 00 2E 00 63 00 6C 00 62 00 0D F0 AD BA 0.5...c. l.b..... 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA 0D F0 AD BA ........ ........ Visual Leak Detector detected 996 memory leaks (942806 bytes). Largest number used: 1496212 bytes. Total allocations: 6841781 bytes. Visual Leak Detector is now exiting. The program '[7336] EasyOPCDADemo.exe: Native' has exited with code 0 (0x0).
19 Mar 2018 13:55 - 19 Mar 2018 15:51 #6160 by federica
Memory leak was created by federica
Hi, I have a problem related to memory resource release.
I'm integrating your library inside my application.
I call "CoInitializeEx(NULL, COINIT_MULTITHREADED);" when I start my CWinApp application and "CoUninitialize();" when I close my application.
Then, the application enters inside a loop during which I call Read method; this is the function I call:
//////////////////////////////////////////////////////////////////////////////////////// void UAController::ReadValue(CString &usraddrs, CString &pwdaddrs, CString &serveraddrs, CString &valaddrs, CString &readValue) //////////////////////////////////////////////////////////////////////////////////////// { _bstr_t usrParam(usraddrs); _bstr_t pwdParam(pwdaddrs); _bstr_t serverParam(serveraddrs); _bstr_t valueParam(valaddrs); _EasyUAClientPtr ClientPtr(__uuidof(EasyUAClient)); try{ if(!usraddrs.IsEmpty() && !pwdaddrs.IsEmpty()) { ClientPtr->Isolated = TRUE; _EasyUAAdaptableParametersPtr IsolatedParameters = ClientPtr->GetIsolatedParameters(); _UASmartSessionParametersPtr SessionParms = IsolatedParameters->GetSessionParameters(); SessionParms->UserIdentity->UserNameTokenInfo->UserName = usrParam; SessionParms->UserIdentity->UserNameTokenInfo->Password = pwdParam; } _UAAttributeDataPtr AttributeDataPtr = ClientPtr->Read(serverParam, valueParam); if(AttributeDataPtr != NULL) { // Display results _variant_t vString; vString.ChangeType(VT_BSTR, &AttributeDataPtr->Value); readValue = vString.bstrVal; } } catch (const _com_error& e) { CString desc( (LPCTSTR) e.Description()); CString errorMessage(e.ErrorMessage()); PrintLocalLog(FALSE, -1, _T("ERROR: %s"), desc); } }
Every time the application calls ReadValue function, the memory allocated to my process increses...
Where I mistake? Should I deallocate any structure?
Thanks!!
Any idea? After some hours, my program blocks my customer's pc..... :dry:
Last edit: 19 Mar 2018 15:51 by federica.
