Importing Type Libraries to Delphi
06 Mar 2018 17:52 #6112 by garysn
Okay, thanks for the information.
I just want to be sure that everything works as intended.
If this is the way QuickOPC handles this issue then I can live with this really small 'restriction' :-)
06 Mar 2018 17:52 #6111 by support
It was not the intent to support Delphi "visible components". QuickOPC provides general COM (and .NET) objects that are to be used from many tools and languages. Due to their diversity, there is sometimes a "friction" - as you have discovered.
Instantiating an object from the code is roughly line only, though.
06 Mar 2018 17:45 #6110 by support
It was not the intent to support "visible components". QuickOPC does not target Delphi specifically; it provides generic COM (and .NET) components that work from any compatible tool or language. Due to diversity of these, there may be a "friction" - as you have described.
Instantiating the object from the code is roughly one line, though.
06 Mar 2018 16:42 #6109 by garysn
Hi, thanks for the fast reply.
No, there are no errors, that's right.
But there are also no new entries in the component palette.
Without these entries I cant't drag the 'visual' components of your OPC library on my Delphi form.
Instead I have to create them at runtime (which means a lot of additional workload).
Does QuickOPC support 'Visible components' in conjunction with Delphi?
06 Mar 2018 08:31 #6104 by support
are these errors preventing you from going further? From what you have posted, it looks like that they are only warning comments in the generated code. If so, you can simply ignore them.
05 Mar 2018 23:15 #6103 by garysn
I'm just evaluating QuickOPC 2018.1 using Delphi XE2 and Delphi Seattle under Win 10 64 bit.
While following the instructions on
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...20Libraries%20to%20Delphi.html
I run into the following problem:
When importing e.g. "OpcLabs BaseLib Core" Delphi is showing the following 71 error messages:
// Fehler beim Erzeugen von Palettenbitmap von (TStringListParsingError) : Server mscoree.dll enthält keine Symbole
// Fehler beim Erzeugen von Palettenbitmap von (TInfo) : Server mscoree.dll enthält keine Symbole
In English: Error creating palette bitmap of ...: Server mscoree.dll does not contain symbols
This happens in Delphi XE2 and Delphi Seattle. Any idea what's going wrong?
Thanks for your help
garysn
