Read multiple values in VBA
06 Feb 2018 10:05 #5967 by dani.hartman@metronik.si
It works!!!
Thank you very much for your help.
Best regards.
04 Feb 2018 10:32 #5943 by support
Replied by support on topic Read multiple values in VBA
Your code does not work because the line
Dim Client As EasyUAClient
should rather be:
Dim Client As New EasyUAClient
Attached is a working Excel sheet that connect to our sample server.
The code looks like this:
Private Sub Workbook_Open() ' Create EasyOPC-UA component Dim Client As New EasyUAClient Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments1.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10845" Dim ReadArguments2 As New UAReadArguments ReadArguments2.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments2.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10853" Dim ReadArguments3 As New UAReadArguments ReadArguments3.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments3.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10855" Dim arguments(2) As Variant Set arguments(0) = ReadArguments1 Set arguments(1) = ReadArguments2 Set arguments(2) = ReadArguments3 ' Read nodes and obtain results. Dim results() As Variant results = Client.ReadMultiple(arguments) Dim ReadResult1 As UAAttributeDataResult: Set ReadResult1 = results(0) Dim ReadResult2 As UAAttributeDataResult: Set ReadResult2 = results(1) Dim ReadResult3 As UAAttributeDataResult: Set ReadResult3 = results(2) ' Display the results. Range("A1") = ReadResult1 Range("A2") = ReadResult2 Range("A3") = ReadResult3 End Sub
The following user(s) said Thank You: dani.hartman@metronik.si
03 Feb 2018 18:16 #5942 by dani.hartman@metronik.si
Thank you for examples.
I've tried to do the similar before - I used the code from other examples but I always got somekind of error.
Now I tried the code from your VB6 example, which is almost like VBA, but when it tries to read (Client.ReadMultiple(arguments)) I get an error:
Run-time error '91'
Object variable or with block variable not set
There is my sample code below. Could you please give me a hint what am I doing wrong :)
Sub Multipla()
If OPCUAServer = "" Then
ReadOPCUAProps
End If
ReadArguments1.EndpointDescriptor.UrlString = OPCUAServer
ReadArguments1.NodeDescriptor.NodeId.expandedText = OPCUATagPrefix & "dbAnalogSensors.TIC_01_29.ScaledMax"
ReadArguments2.EndpointDescriptor.UrlString = OPCUAServer
ReadArguments2.NodeDescriptor.NodeId.expandedText = OPCUATagPrefix & "dbAnalogSensors.TIC_01_30.ScaledMax"
ReadArguments3.EndpointDescriptor.UrlString = OPCUAServer
ReadArguments3.NodeDescriptor.NodeId.expandedText = OPCUATagPrefix & "dbAnalogSensors.LI_01_37.ScaledMax"
' Obtain values. By default, the Value attributes of the nodes will be read.
End Sub
02 Feb 2018 19:58 #5938 by support
you are right that this example is missing - it is simply due to the sheer amount of combinations we would have to write.
There are, however, related examples that may help you.
First, there is an example for reading multiple values in Excel VBA - but for OPC Classic. It is in file ReadAndDisplayMultipleValues.xls, and looks like this:
Private Sub Workbook_Open() ' Create EasyOPC-DA component Dim Client As New EasyDAClient ' Define OPC item IDs Dim ReadItemArguments1: Set ReadItemArguments1 = New DAReadItemArguments ReadItemArguments1.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments1.ItemDescriptor.ItemID = "Simulation.Random" Dim ReadItemArguments2: Set ReadItemArguments2 = New DAReadItemArguments ReadItemArguments2.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments2.ItemDescriptor.ItemID = "Trends.Ramp (1 min)" Dim ReadItemArguments3: Set ReadItemArguments3 = New DAReadItemArguments ReadItemArguments3.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments3.ItemDescriptor.ItemID = "Trends.Sine (1 min)" Dim ReadItemArguments4: Set ReadItemArguments4 = New DAReadItemArguments ReadItemArguments4.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments4.ItemDescriptor.ItemID = "Simulation.Register_I4" Dim arguments(3) As Variant Set arguments(0) = ReadItemArguments1 Set arguments(1) = ReadItemArguments2 Set arguments(2) = ReadItemArguments3 Set arguments(3) = ReadItemArguments4 ' Read item values Dim valueResults() valueResults = Client.ReadMultipleItemValues(arguments) ' Display the item values For i = 0 To 3 Range("A1").Offset(i, 0).Value = valueResults(i).Value Next i End Sub
Second, there are examples for reading multiple UA values in VB 6, which should be very close to VBA. They are under VB\VB60\UADocExamples, in EasyUAClientForm.frm; you can open it with a text editor, without having VB6. For convenience, here are they:
Rem This example shows how to read the attributes of 4 OPC-UA nodes at once, and display the results. Private Sub ReadMultiple_Main_Command_Click() OutputText = "" Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments1.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10853" Dim ReadArguments2 As New UAReadArguments ReadArguments2.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments2.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10845" Dim ReadArguments3 As New UAReadArguments ReadArguments3.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments3.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10304" Dim ReadArguments4 As New UAReadArguments ReadArguments4.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments4.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10389" Dim arguments(3) As Variant Set arguments(0) = ReadArguments1 Set arguments(1) = ReadArguments2 Set arguments(2) = ReadArguments3 Set arguments(3) = ReadArguments4 ' Instantiate the client object Dim Client As New EasyUAClient ' Obtain values. By default, the Value attributes of the nodes will be read. Dim results() As Variant results = Client.ReadMultiple(arguments) ' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As UAAttributeDataResult: Set Result = results(i) OutputText = OutputText & "results(" & i & ").AttributeData: " & Result.AttributeData & vbCrLf Next End Sub
Rem This example shows how to read the Value attributes of 3 different nodes at once. Using the same method, it is also possible Rem to read multiple attributes of the same node. Private Sub ReadMultipleValues_Main_Command_Click() OutputText = "" ' Instantiate the client object Dim Client As New EasyUAClient Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments1.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10845" Dim ReadArguments2 As New UAReadArguments ReadArguments2.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments2.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10853" Dim ReadArguments3 As New UAReadArguments ReadArguments3.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" ReadArguments3.NodeDescriptor.NodeId.expandedText = "nsu=http://test.org/UA/Data/;i=10855" Dim arguments(2) As Variant Set arguments(0) = ReadArguments1 Set arguments(1) = ReadArguments2 Set arguments(2) = ReadArguments3 ' Obtain values. By default, the Value attributes of the nodes will be read. Dim results() As Variant results = Client.ReadMultipleValues(arguments) ' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As ValueResult: Set Result = results(i) OutputText = OutputText & "Value: " & Result.value & vbCrLf Next ' Example output: ' 'Value: 8 'Value: -8.06803E+21 'Value: Strawberry Pig Banana Snake Mango Purple Grape Monkey Purple? Blueberry Lemon^ End Sub
Rem This example shows how to read the attributes of 4 OPC-UA nodes specified by browse paths at once, and display the results. Private Sub ReadMultiple_BrowsePath_Command_Click() OutputText = "" Dim BrowsePathParser As New UABrowsePathParser BrowsePathParser.DefaultNamespaceUriString = "http://test.org/UA/Data/" Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" Set ReadArguments1.NodeDescriptor.BrowsePath = BrowsePathParser.Parse("[ObjectsFolder]/Data/Dynamic/Scalar/FloatValue") Dim ReadArguments2 As New UAReadArguments ReadArguments2.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" Set ReadArguments2.NodeDescriptor.BrowsePath = BrowsePathParser.Parse("[ObjectsFolder]/Data/Dynamic/Scalar/SByteValue") Dim ReadArguments3 As New UAReadArguments ReadArguments3.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" Set ReadArguments3.NodeDescriptor.BrowsePath = BrowsePathParser.Parse("[ObjectsFolder]/Data/Static/Array/UInt16Value") Dim ReadArguments4 As New UAReadArguments ReadArguments4.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer" Set ReadArguments4.NodeDescriptor.BrowsePath = BrowsePathParser.Parse("[ObjectsFolder]/Data/Static/UserScalar/Int32Value") Dim arguments(3) As Variant Set arguments(0) = ReadArguments1 Set arguments(1) = ReadArguments2 Set arguments(2) = ReadArguments3 Set arguments(3) = ReadArguments4 ' Instantiate the client object Dim Client As New EasyUAClient ' Obtain values. By default, the Value attributes of the nodes will be read. Dim results() As Variant results = Client.ReadMultiple(arguments) ' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As UAAttributeDataResult: Set Result = results(i) OutputText = OutputText & "results(" & i & ").AttributeData: " & Result.AttributeData & vbCrLf Next End Sub
If the examples don't help, please post your code and the error you are getting.
BTW, have you considered whether the Excel Option would not be an easier solution? (of course VBA is more powerful - it depends on the usage case).
02 Feb 2018 11:03 #5933 by dani.hartman@metronik.si
Could you please send me an example how to read multiple values from OPC UA server in VBA code. I couldn't find this kind of example among the other Excel examples and the description in help is also not detailed enough for VBA code…
I'm strugling with this issue for some time now and I always get some kind of VBA error. Otherwise reading and writing one value and also subscribing to multiple values works fine.
Thank you in advance and best regards
