Cannot Compile mscorlib.tlh (C++, VS 2017)
05 Dec 2017 18:25 #5712 by support
Oh, great.
Sorry that I had you waiting - but in the end, it would have been impossible for me to figure it out anyway, without having your source code that contained the cause.
05 Dec 2017 18:13 #5711 by MPick
I figured this out, somewhere I had a #define or ||, which was overlapping with the function argument 'or' used in the .tlh file. The solution was to undefine that macro before including QuickOPC.h
Thanks!
04 Dec 2017 20:51 #5710 by MPick
Thanks for the quick reply, here you go.
04 Dec 2017 20:28 - 04 Dec 2017 20:29 #5709 by support
can you post the generated mscorlib.tlh file too?
(please zip it first)
Last edit: 04 Dec 2017 20:29 by support.
04 Dec 2017 19:35 #5708 by MPick
I've attempted to add quick OPC to our visual studio project. As far as I can tell I've replicated the project setup from the examples (which I re-targeted to the v141 toolset and compiled just fine.)
Based on the headers in the examples, the header where I would like to interface with Quick OPC looks like this:
#pragma once #ifndef _WIN32_WINNT // Specifies that the minimum required platform is Windows Vista. #define _WIN32_WINNT 0x0600 // Change this to the appropriate value to target other versions of Windows. #endif #include <stdio.h> #include <tchar.h> #define _ATL_CSTRING_EXPLICIT_CONSTRUCTORS // some CString constructors will be explicit #include <atlbase.h> #include <atlstr.h> #include <atlcom.h> #include <atlsafe.h> #include <comutil.h> #include "QuickOpc.h"
I've copied the SDK folder into my visual studio project (it's policy for us to keep our dependencies in a 'deps' folder), and set up VS to copy the appropriate files to our output directory + correctly link QuickOPC.h.
However when I try to compile I run into problems with mscorlib.tlh (& .tli), many syntax errors are thrown. Many of the errors look like:
13:39:07.787 1>c:\users\admin\documents\projects\pcs\pcs\pcs-supervisor\x64\debug\mscorlib.tlh(12974): error C2143: syntax error: missing ')' before '||' 13:39:07.788 1>c:\users\admin\documents\projects\pcs\pcs\pcs-supervisor\x64\debug\mscorlib.tlh(12974): error C2143: syntax error: missing ';' before '||' 13:39:07.788 1>c:\users\admin\documents\projects\pcs\pcs\pcs-supervisor\x64\debug\mscorlib.tlh(12974): error C2059: syntax error: '||' 13:39:07.788 1>c:\users\admin\documents\projects\pcs\pcs\pcs-supervisor\x64\debug\mscorlib.tlh(12974): error C2059: syntax error: ')'
See the attached file 'pcs-supervisor.log' which is the build log (with the highest verbosity) from visual studio for more. I have also included the projects .vcxproj file.
Is there a setting in my configuration that is incompatible with mscorlib? I've googled around already no no avail.
Please let me know if there's any other useful information I can provide.
(PS, sorry for resubmitting, files didn't attach.)
