Example for freepascal not working in QuickOPC2017.1
02 Nov 2017 15:09 #5635 by support
Oh, that's great.
Let me know should you need more help.
The following user(s) said Thank You: mcbrief
02 Nov 2017 14:57 #5634 by mcbrief
Thank you very much. I reimported the libraries again and now it works fine!
I see, I did something wrong by importing the libraries. Sorry!
I'm very happy that it is working now with the actual QuickOPC Version. Thanks!
02 Nov 2017 14:11 #5633 by mcbrief
Thank you for the quick response!
I tried both. I tried to reimport the libraries to a completely new project and I tried simply to compile the old Project new. Both didn't work.
Perhaps I did something wrong by reimporting? I took the description in kb.opclabs.com/First_experiences_using_QuickOPC_with_Free_Pascal_(Lazarus) .
After the descriped changes I was able to compile successfull, but with the same error message at runtime.
Kind regards
02 Nov 2017 13:40 #5632 by support
Have you re-imported the type libraries, or are you just building/running your project, created with the earlier version?
02 Nov 2017 13:33 #5631 by mcbrief
Last year I tried QuickOPC2016.2 and the examples were working well with Lazarus. Now I tried the same with QuickOPC2017.1 but I didn't get the examples working.
Every time I call a "Client.ReadValue" or "Client.WriteValue" command, I get the debugger errormessage "External: SIGSEGV".
I'm using the actual Lazarus IDE v1.6.4 with Freepascal 3.0.2. in Windows 10, 64bit.
Does somebody has any idea? Or shall I wait for QuickOPC2017.2 or QuickOPC2018.1?
Thank you very much for your help!
Kind regards
