Getting OPC property values in Delphi
06 Sep 2017 14:35 #5494 by support
The example comes with the product and is in the documentation. See the DocExamples sample project for Delphi, and in it, the _easyDAClient.GetMultiplePropertyValues.Main.inc file:
// This example shows how to get value of multiple OPC properties. // // Note that some properties may not have a useful value initially (e.g. until the item is activated in a group), which also the // case with Timestamp property as implemented by the demo server. This behavior is server-dependent, and normal. You can run // IEasyDAClient.ReadMultipleItemValues.Main.vbs shortly before this example, in order to obtain better property values. Your // code may also subscribe to the items in order to assure that they remain active. class procedure GetMultiplePropertyValues.Main; var Arguments: OleVariant; Client: TEasyDAClient; I: Cardinal; PropertyArguments1: _DAPropertyArguments; PropertyArguments2: _DAPropertyArguments; PropertyArguments3: _DAPropertyArguments; PropertyArguments4: _DAPropertyArguments; Result: _ValueResult; Results: OleVariant; begin PropertyArguments1 := CoDAPropertyArguments.Create; PropertyArguments1.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; PropertyArguments1.NodeDescriptor.ItemID := 'Simulation.Random'; PropertyArguments1.PropertyDescriptor.PropertyId.NumericalValue := DAPropertyIds_Timestamp; PropertyArguments2 := CoDAPropertyArguments.Create; PropertyArguments2.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; PropertyArguments2.NodeDescriptor.ItemID := 'Simulation.Random'; PropertyArguments2.PropertyDescriptor.PropertyId.NumericalValue := DAPropertyIds_AccessRights; PropertyArguments3 := CoDAPropertyArguments.Create; PropertyArguments3.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; PropertyArguments3.NodeDescriptor.ItemID := 'Trends.Ramp (1 min)'; PropertyArguments3.PropertyDescriptor.PropertyId.NumericalValue := DAPropertyIds_Timestamp; PropertyArguments4 := CoDAPropertyArguments.Create; PropertyArguments4.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; PropertyArguments4.NodeDescriptor.ItemID := 'Trends.Ramp (1 min)'; PropertyArguments4.PropertyDescriptor.PropertyId.NumericalValue := DAPropertyIds_AccessRights; Arguments := VarArrayCreate([0, 3], varVariant); Arguments[0] := PropertyArguments1; Arguments[1] := PropertyArguments2; Arguments[2] := PropertyArguments3; Arguments[3] := PropertyArguments4; // Instantiate the client object Client := TEasyDAClient.Create(nil); TVarData(Results).VType := varArray or varVariant; TVarData(Results).VArray := PVarArray( Client.GetMultiplePropertyValues(PSafeArray(TVarData(Arguments).VArray))); // Display results for I := VarArrayLowBound(Results, 1) to VarArrayHighBound(Results, 1) do begin Result := IInterface(Results[I]) as _ValueResult; WriteLn('results(', i, ').Value: ', Result.Value); end; end;
06 Sep 2017 13:56 #5493 by alr1976
Hi!
It possible to have a Delphi demo to read properties in opc da?
I have read Vb example but it use old opc library and now I have ServerDescription and node scriptor.
Br,Alessandro
