Disconnect
02 May 2017 09:17 #5125 by VFoxpro
Replied by VFoxpro on topic Disconnect
Thank you for your assistance. I will download the updated version and do some further testing.
Best regards!
01 May 2017 06:08 #5122 by support
Replied by support on topic Disconnect
I was able to reproduce the problem. Thank you once again for reporting it.
We have made a fix. It is available in recent build of QuickOPC 2016.2, which is now available from the Download area on this site. Internal version is 5.41.1186.1 or later.
The following user(s) said Thank You: VFoxpro
28 Apr 2017 12:00 #5119 by support
Thank you for the findings. I will attempt to reproduce and investigate here. I will reply through the forums when I have some new information.
28 Apr 2017 11:56 #5118 by VFoxpro
Hello again!
Are you saying that this is not happening ?
In order to get a second opinion, I tried the same with Windows PowerShell 2.0:
Windows PowerShell Copyright (C) 2009 Microsoft Corporation. Alle Rechte vorbehalten. PS C:\Users\kemme> $oClient = new-object -com OPCLabs.EasyOpc.DataAccess.EasyDAClient PS C:\Users\kemme> $oClient.InstanceParameters.Timeouts.ReadItem = 5000 PS C:\Users\kemme> $Value = $oClient.ReadItemValue("", "Matrikon.OPC.Simulation.1", "DM1_SPS.nProdukt") PS C:\Users\kemme> write-host $Value 12
Same effect: The connection does not timeout at all.
So, it's not only a Foxpro related question. It seems to be a COM related issue ...
Regards!
28 Apr 2017 09:11 #5113 by VFoxpro
Hello!
QuickOPC manages the connections automatically. There I a chapter about in the User's Guide.
Meanwhile I discovered that chapter ... :whistle:
No disconnect at all. Not after 30s, 30minutes or even 30 hours. I have no subscriptions. Just a single ReadItemValue as shown below.
oClient = CREATEOBJECTEX("OPCLabs.EasyOpc.DataAccess.EasyDAClient", "")
? oClient.ReadItemValue("", "Matrikon.OPC.Simulation.1", "DM1_SPS.nProdukt")
RELEASE oClient
Even releasing the Object oClient does not lead to a disconnect.
Matrikon Server still indicates two connections, which is Foxpro and the Matrikon OPC-Explorer.
Quitting Visual Foxpro disconnects from the server.
Regards!
28 Apr 2017 05:26 - 28 Apr 2017 05:26 #5112 by support
In this particular case, after a single Read, and if nothing else is in play (such as no subscriptions), QuickOPC should disconnect roughly 30-32 seconds after the Read (but not immediately; the time is also configurable).
Last edit: 28 Apr 2017 05:26 by support.
27 Apr 2017 14:50 #5111 by VFoxpro
I started testing EasyOPC DataAccess with Visual Foxpro 9.
After creating an instance with CREATEOBJECT("OPCLabs.EasyOpc.DataAccess.EasyDAClient") followed by ReadItemValue() a connection to the OPC-Server will be established.
How can I disconnect from the OPC-Server? Without quitting the whole application ...
Regards!
27 Apr 2017 14:40 #5110 by VFoxpro
Disconnect was created by VFoxpro
I just started testing QuickOPC with Visual Foxpro 9.
After creating a client instance CREATEOBJECT("OPCLabs.EasyOpc.DataAccess.EasyDAClient") the OPC-Server will be connected with the following ReadItemValue().
How can I disconnect from the OPC-Server ? Without quitting the whole application ...
Regards!
