Opcua server problem
27 Feb 2017 12:18 #4973 by support
Replied by support on topic Opcua server problem
Please post the full error message. The interpretation of the numbers depends on the kind of error we are dealing with.
Assuming for the rest of this answer that, from the error message, the number 0x80131500 represents an OPC UA StatusCode, then it stands for BadSecurityChecksFailed (CodeBits = 0x8013; with additional FlagBits = 0x1500).
This is most likely generated on the server side - it looks like that the server isn't happy with the way the client connects to it, security-wise. Try to investigate on the server, what precisely it is complaining about.
27 Feb 2017 07:01 #4971 by alr1976
Opcua server problem was created by alr1976
Hi!
I subscribe tags and works fine. If i have disconnection ,server reconnect it perfectly. I have only 1 problem. After 1 day i have error 0x80131500 and server doesn t connect anymore....
