Python code (error 'invalid class string')
21 Nov 2023 13:41 #12404 by support
29 Nov 2016 17:57 #4608 by support
cam you please answer following:
1. Which of our examples are you running (please state the file name)? Or, if you are running something code from the Web, or if you have made any changes, please post the whole code here.
2. Please specify which line of code gives the error.
3. Which choices have you made during installation - specifically, on the wizard dashboard page, have you kept the default choice, or have you selected something else?
29 Nov 2016 17:35 #4607 by support
Sent: Tuesday, November 29, 2016 1:52 PM
hi,
I run your example in python and get an error 'invalid class string'.
please can you explain what i need to do to connect to the OPC server as in your python example.
Time to create page: 0.260 seconds
