C++ Notive console apllication need to read from OPC server cache.
06 Sep 2016 12:14 #4327 by support
That's easy:
ReadItemArguments1Ptr->ReadParameters->DataSource = DADataSource_Cache;
because DataSource property gets transformed from TLB to:
__declspec(property(get=GetDataSource,put=PutDataSource)) enum DADataSource DataSource;
and DADataSource is defined as:
enum __declspec(uuid("b0e1f79b-7601-44b3-8013-9398e4151091")) DADataSource { DADataSource_ByValueAge = 0, DADataSource_Cache = 1, DADataSource_Device = 2 };
06 Sep 2016 10:49 #4326 by olab
In attached code i need to set this to read from OPC servers cache and not directly from the device. I just can't get the syntax on this line. Can someone help me?
#include "stdafx.h"
#include <atlsafe.h>
#include <comutil.h>
#include <iostream>
using namespace std;
#import "libid:BED7F4EA-1A96-11D2-8F08-00A0C9A6186D" // mscorlib
using namespace mscorlib;
#import "libid:ecf2e77d-3a90-4fb8-b0e2-f529f0cae9c9" // OpcLabs.BaseLib
using namespace OpcLabs_BaseLib;
#import "libid:14D1A788-0333-4D64-8547-8FB0357408EF" // OpcLabs.EasyOpcClassicInternal
using namespace OpcLabs_EasyOpcClassicInternal;
#import "libid:1F165598-2F77-41C8-A9F9-EAF00C943F9F" // OpcLabs.EasyOpcClassic
using namespace OpcLabs_EasyOpcClassic;
int _tmain(int argc, _TCHAR* argv[])
bool exit = false;
while (exit == false)
// Initialize the COM library
CoInitialize(NULL);
// Instatiate the EasyOPC-DA client object
_EasyDAClientPtr ClientPtr(__uuidof(EasyDAClient));
_DAReadItemArgumentsPtr ReadItemArguments1Ptr(_uuidof(DAReadItemArguments));
ReadItemArguments1Ptr->ServerDescriptor->MachineName = L"";
ReadItemArguments1Ptr->ServerDescriptor->ServerClass = L"Kepware.KEPServerEx.V5";
ReadItemArguments1Ptr->ItemDescriptor->ItemId = L"Simulation Examples.Functions.Ramp2";
//ReadItemArguments1Ptr->DAReadParameters->DADataSource = 1;
//THIS WON't WORK
ReadItemArguments1Ptr->ReadParameters->DataSource = 1;
CComSafeArray<VARIANT> ArgumentsArray(1);
ArgumentsArray.SetAt(0, _variant_t((IDispatch*)ReadItemArguments1Ptr));
LPSAFEARRAY pArgumentsArray = ArgumentsArray.Detach();
CComSafeArray<VARIANT> ResultArray(ClientPtr->ReadMultipleItems(&pArgumentsArray));
ArgumentsArray.Attach(pArgumentsArray);
for (int i = ResultArray.GetLowerBound(0); i <= ResultArray.GetUpperBound(0); i++)
_DAVtqResultPtr DAVtqResultPtr(ResultArray);
_DAVtqPtr DAVtqPtr(DAVtqResultPtr->Vtq);
variant_t res = DAVtqPtr->Value;
cout << res.fltVal;
cout << endl;
// Release all interface pointers BEFORE calling CoUninitialize()
ResultArray.Destroy();
ClientPtr = NULL;
CoUninitialize();
Sleep(1000);
return 0;
