Writing PHP Error
30 May 2016 16:09 #4075 by support
Replied by support on topic Writing PHP Error
Maybe because you have use $client instead of $Client ? AFAIK, variable names are case sensitive in PHP.
30 May 2016 15:56 #4074 by pburgos
Writing PHP Error was created by pburgos
According to an example in another post i have the following code:
<html>
<head><t-itle>OPC</title></head>
<body>
<?php
// Create EasyOPC-DA component
$Client = new COM("OpcLabs.EasyOpc.DataAccess.EasyDAClient");
// Read item value and display it
print $Client->ReadItemValue("","Kepware.KEPServerEX.V5","Test.My_device.Tag1");
print $client->WriteItemValue("","Kepware.KEPServerEX.V5","Test.My_device.Tag1",1);
</body>
</html>
I can write to the tag "Tag1" Direct from kepware, but when trying from the code above it returns this error: Fatal error: Call to a member function WriteItemValue() on null
Any ideas?
Time to create page: 0.425 seconds
