The type initializer for ...EasyDAClient threw an exception
14 Mar 2016 11:47 #3924 by support
Thank you very much.
I have tried to reproduce this today. I have used:
- Windows 7 Enterprise (x64, English)
- Office Professional Plus 2013 with SP1 (English)
- QuickOPC 5.35.442.1
- Wireshark 2.0.2 (Win64) with pcap
I can confirm that Wireshark installs Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501.
But, I was unable to reproduce the problem. My test application in Microsoft Access was working after Wireshark installation correctly.
Still, what you reported sounds possible. QuickOPC 5.35 indeed uses Visual C++ 2013 internally, and some kind of collision cannot be ruled out. I will continue looking into the issue a bit more, and if I find something, will report it here.
  • alexf
24 Feb 2016 11:21 #3884 by alexf
I have used the most recent version from the download site.
After I installed Wireshark, I had the version 12.0.30501.0 (X64) installed from the VC++ redistributable.
24 Feb 2016 08:53 #3883 by support
Oh great. Sorry that we have not reacted earlier. I am glad that you have found a solution yourself; it would be difficult for us to figure this out remotely anyway.
BTW, which version of QuickOPC are you using? I am asking because in recent versions, we attempt to "invisibly" bundle such redistributables with our assemblies, so theoretically it should not happen. And I would therefore like to know whether it is because you have an older version, or because this bundling still cannot overcome such conflicting installs.
  • alexf
24 Feb 2016 07:55 #3882 by alexf
Ok, solution found!
I had installed the Wireshark package. With it came the Visual Studio C++ 2013 Redistributable package that caused this issue.
I uninstalled the OPC client, installed Wireshark and installed the OPC Client again.
  • alexf
23 Feb 2016 14:05 #3881 by alexf
Hello community!
It is me again. After testing an Access solution for some days I am having a problem today. When I open the access data base, a form is opened and in the form_load event I create my opc client.
The opcClient is defined module variable via
Private WithEvents opcClient As EasyDAClient
In the Form_Load event i initialize the opcClient via
Set opcClient = New EasyDAClient. But since today it throws an exception
Runtime error 80131534
The type initializer for 'OpcLabs.EasyOpc.DataAccess.EasyDAClient' threw an exception.
I tried the VBS scripts from the example folder. Those scripts are running.
Do you have any idea that could influence the behavior in Microsoft Access?
Thank you for your help.
