Topic not updated with quality that is not bad (timeout)
  • alexf
22 Feb 2016 11:40 #3872 by alexf
Hello!
I am using ReadItemValue.
So I will try the ReadItem method and dig further into this issue.
22 Feb 2016 10:57 #3871 by support
Is that ReadItem/ReadMultipleItems or ReadItemValue/ReadMultipleItemValues?
Assuming that you are calling ReadItemValue/ReadMultipleItemValues:
These methods return just the actual Value, while OPC server always supplies a triple of Value/Timestamp/Quality. Since the Value is generally only available when the Quality is Good/Uncertain, these methods set up an additional subscription to observe the values wait until the quality becomes Good or at least Uncertain. If the server does not supply a VTQ with a Good/Uncertain quality within a timeout period, there is no Value we can give you, and you receive this error.
You can use ReadItem/ReadMultipleItems instead. In that case, you receive the whole VTQ - and it is then up to you (your code) to decide what to do if the Quality is not Good/Uncertain and therefore there is no Value to talk about.
  • alexf
22 Feb 2016 09:06 #3870 by alexf
Hello Support!
While executing a read command, I get the following error message.
Error Details:
Description: "Topic not updated with quality that is not bad (timeout)"
Number: -1073430513
Source: "OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient"
Can you give me some details what this error message means as I could not search in the online help, and the Reference chm file could not be downloaded (Error 404).
