Separate Connections
10 Jun 2015 08:40 #3198 by support
Replied by support on topic Separate Connections
Please check your QuickOPC version and build. The issue should be solved in builds 5.34.205.1 and higher.
Besides, if the second connection takes considerably more time to establish than the first, then there appears to be some kind of server issue as well.
10 Jun 2015 08:38 #3197 by support
Separate Connections was created by support
Sent: Tuesday, June 09, 2015 11:31 PM
Subject: OPC Labs Contact Form - Separate Connections
i am using the demo version of QUICKOPC to make a connection with a OPC server. I notice that when a subscribe and write, there are to separate connections made. The seccond connection is taking a long time to establish. My question now is that the problem, which also appears in this article ( www.opclabs.com/forum/connections-reconnections-com-dcom/160...-connections-to-the-opc-server ) is solvable.
Kind regards,
N.
