QuickOPC install in Visual Studio 2010 C++. ReadMultipleItems example
28 May 2014 06:31 #2006 by support
I do not see a product related question here, sorry.
27 May 2014 07:18 - 27 May 2014 07:22 #2003 by forestro
I created an OPC class to acess OPC server which is used in another class. I don't use the main function and I would like to use a signal when there is an itemchanged event.
In attachments : OPC_Client.h (header file) and OPC_Client.cpp
Last edit: 27 May 2014 07:22 by forestro.
27 May 2014 06:28 #2001 by support
The example in C++ I referred to ( www.opclabs.com/forum/com-reading-writing-subscriptions-prop...scribemultipleitems-in-vc#1996 ) does almost exactly the same thing as the C# example you listed, i.e. it subscribes to multiple OPC items, and prints out the values as they come in.
The other C++ example in this thread reads the values explicitly, and also prints them out.
If needed, the two examples can be combined together.
What precisely is it that you don't understand?
26 May 2014 13:32 #1999 by forestro
Thanks you for this example but I need an example in c++ as C# example :
// This example shows how subscribe to changes of multiple items and display the value of the item with each change.
2
3using JetBrains.Annotations;
4using OpcLabs.EasyOpc.DataAccess;
5using System;
6using System.Threading;
7
8namespace DocExamples
9{
10 namespace _EasyDAClient
11 {
12 partial class SubscribeMultipleItems
13 {
14 public static void Main()
15 {
16 using (var easyDAClient = new EasyDAClient())
17 {
18 easyDAClient.ItemChanged += easyDAClient_ItemChanged;
19
20 easyDAClient.SubscribeMultipleItems(
21 new[] {
22 new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Random", 1000, null),
23 new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Ramp (1 min)", 1000, null),
24 new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Sine (1 min)", 1000, null),
25 new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Register_I4", 1000, null)
26 });
27
28 Console.WriteLine("Processing item changed events for 1 minute...");
29 Thread.Sleep(60 * 1000);
30 }
31 }
32
33 // Item changed event handler
34 static void easyDAClient_ItemChanged([NotNull] object sender, [NotNull] EasyDAItemChangedEventArgs e)
35 {
36 Console.WriteLine("{0}: {1}", e.ItemDescriptor.ItemId, e.Vtq);
37 }
38 }
39 }
40}
I created an OPC client class which use subscribe and read item. I would like to read item when it changes. I don't understand your example and how to add it in my class.
26 May 2014 08:47 #1997 by support
26 May 2014 08:36 #1995 by support
Regarding instantiating the EasyDAClient in a file different from the declaration: Not sure what you mean - can you describe the problem in more detail?
Regarding "ReadItems" example: under the QuickOpcComCppExamples solution, there is Win32\ReadMultipleItems example. Its main part looks like this:
// Copyright (c) CODE Consulting and Development, s.r.o., Plzen. All rights reserved. // ReadMultipleItems.cpp : Defines the entry point for the console application. // #include "stdafx.h" #include <atlsafe.h> #include <comutil.h> #import "libid:FAB7A1E3-3B79-4292-9C3A-DF39A6F65EC1" version(5.2) // EasyOpcLib using namespace EasyOpcLib; int _tmain(int argc, _TCHAR* argv[]) { // Initialize the COM library CoInitialize(NULL); // Instatiate the EasyOPC-DA client object IEasyDAClientPtr EasyDAClientPtr(__uuidof(EasyDAClient)); CComSafeArray<BSTR> ItemIdArray(4); ItemIdArray[0] = _T("Simulation.Random"); ItemIdArray[1] = _T("Trends.Ramp (1 min)"); ItemIdArray[2] = _T("Trends.Sine (1 min)"); ItemIdArray[3] = _T("Simulation.Register_I4"); CComVariant vMissing; vMissing.vt = VT_ERROR; CComVariant vResults(EasyDAClientPtr->ReadMultipleItems(_T(""), _T("OPCLabs.KitServer.2"), CComVariant(ItemIdArray.Detach()), vMissing)); CComSafeArray<VARIANT> ResultArray(vResults.parray); for (int i = ResultArray.GetLowerBound(0); i <= ResultArray.GetUpperBound(0); i++) { IDAVtqResultPtr DAVtqResultPtr(ResultArray[i]); IDAVtqPtr DAVtqPtr(DAVtqResultPtr->Vtq); _tprintf(_T("results(%d).Vtq.ToString(): %s\n"), i, DAVtqPtr->ToString().bstrVal); } // Release all interface pointers BEFORE calling CoUninitialize() ResultArray.Destroy(); vResults.Clear(); EasyDAClientPtr = NULL; CoUninitialize(); TCHAR line[80]; _putts(_T("Press Enter to continue...")); _fgetts(line, sizeof(line), stdin); return 0; }
An example with ItemChanged event: will be in a separate post.
22 May 2014 08:57 #1988 by forestro
I need an example of using of itemChanged event for one item in Visual Studio c++ COM project.
Thanks you.
21 May 2014 08:57 #1986 by forestro
I referred to erros generated by IntelliSense. This problem is resolved.
I have a lot of problems to program with QuickOPC-COM. Do you have an example to Instatiate the EasyOPC-DA client object in a file different of the declaration. And examples with ReadItems, subsribeitem using std::string and an example with itemchanged event.
Thanks you.
19 May 2014 21:03 #1982 by support
Are you referring to errors generated by IntelliSense, or actual build errors?
If you are describing IntelliSense, the solution is: ignore them.
If you are dealing with build errors, can you do a Rebuild of our original project, and post a full content of the Output windows here?
19 May 2014 08:57 #1978 by forestro
I have used the second possibility with the "COM Visual C++ Example (VS 2008).
I copied these sentences and paste in my header file :
#import "libid:FAB7A1E3-3B79-4292-9C3A-DF39A6F65EC1" version(5.2) exclude("_IEasyDAClientEvents") // EasyOpcDALib
#import "libid:965A3842-AEEA-4DF9-9241-28B963F76E24" version(5.2) // OPCUserObjects
using namespace OPCUserObjects;
There are the same error in my project and in your project : "impossible to open the source file".
Are there files to add in my project ?
