I need subscribeMultipleItems and Servers
05 Feb 2014 13:31 #1702 by support
This means you are using an older version of QuickOPC (not the current 5.30).
I suggest that you download the latest.
But the solution/projects in your installation, under Examples/CPP/VS2008, are essentially the same.
05 Feb 2014 13:08 #1701 by Bego
I have no such directory, only I have / Examples/CPP/VS2008
thank you
05 Feb 2014 12:29 #1700 by support
Dear Sir/Madam,
The source code of EasyOPCDADemo is installed with the product, the solution with the project is under Examples\CPP\VS2012. There is also a shortcut to this solution, from the product's folder in Start menu, under Examples.
The SubscribeMultipleItems example is not precisely there, but I suggest that you open the existing examples first and start from there. If you then have further questions, come back to this forum.
05 Feb 2014 12:20 #1699 by Bego
Hi, I need to add the. Dll to a VC + + project and subscribe to various items of multiple servers, and do not know where to start.
Would there be any way to see the source of the Demo Application Applicaton (COM)?
thank you very much,
