reading data from siemens OPC-UA server
13 May 2021 16:26 #9674 by support
that would be, for example,
Range("D6").Value = Client.ReadValue("opc.tcp://192.168.72.12:4840", "nsu=http://www.siemens.com/simatic-s7-opcua ;ns=3;s=""dbTraceBack"".""StepResponse""")
Note: This appears not to be using Excel Option (the category of the forum post you have chosen) - it is VBA in Excel I suppose, which is a different thing.
The Excel Option allows to achieve the same without coding.
The following user(s) said Thank You: hj.weyrich@jopp.com
13 May 2021 16:04 #9673 by hj.weyrich@jopp.com
i'm testing the functions of the EASYUA-client and do not know how to set the parameters.
Can someone tell me the correct parameters in EASYUA-Client to get the data of a Siemens OPC-UA server.
In den Connectivity Explorer i found the field with this settings:
="opc.tcp://192.168.72.12:4840, BrowsePath=""[ObjectsFolder]/CPU.DataBlocksGlobal/dbTraceBack.StepResponse"""
OPC-UA Node
Node Id: nsu=http://www.siemens.com/simatic-s7-opcua ;ns=3;s="dbTraceBack"."StepResponse"
Browse Path (*): [ObjectsFolder]/CPU.DataBlocksGlobal/dbTraceBack.StepResponse
Node Class: Variable
Browse Name: StepResponse
Type Definition: BaseDataVariableType
Reference Type Id: HasComponent
What i have to type in the parameter values?
Range("D6").Value = Client.ReadValue("???","???")
Thanks in advance.
Hans-Jürgen
