array fields
04 Jan 2021 18:29 #9328 by support
Replied by support on topic array fields
this is very good question.
You currently cannot get the whole array at once into Excel, because Excel values are scalar-typed only.
But, you can get individual array elements into individual Excel cells, and arrange them the way you like (e.g. row-wise or column-wise).
The procedure for extracting a single array element is describe here: kb.opclabs.com/How_to_extract_array_elements_in_Excel_Option . By varying the index, you can obtain different elements.
I hope this helps
The following user(s) said Thank You: Opclabs9999
04 Jan 2021 15:49 #9327 by Opclabs9999
array fields was created by Opclabs9999
Hi, scalar type can be imported in Excel while vectors cannot ( instead of the values I can only see a Systen.Single[] label )
Is there a way to obtain all values inside the vector ?
Example image attached
